gas tank leaking
gas tank leaking
i was driving my acura tl 2.5 98 and i was smelling gas , so i stoped the car and i seen gas driping from the tank cant see if its a line becasue of the plastic cover .. dont know what to do or how to fix issue,,
You'll may have to drop the tank to fix. Leak could be at fittings on top of car. Check fittings under the fill tube.
Fuel line corrosion can cause leaks almost anywhere. You may need to replace all tubing beneath the car.
good luck
good luck
