Fuel Filter
Old Jul 13, 2012 | 06:24 PM
98LineCook's Avatar
Fuel Filter
Where is it and how easy is it to replace it? I tried looking for a manual but I can't find one
98 TL 2.5
Old Jul 14, 2012 | 08:55 AM
main70072's Avatar
In engine compartment on driver's firewall.
Old Jul 14, 2012 | 03:53 PM
tempetom's Avatar
Hope this helps?
File Type: pdf
Old Jul 14, 2012 | 04:12 PM
98LineCook's Avatar
sweet dude. many thanks!
I know I saw a DIY for fixing the brake switch and I keep searching but nothing comes up. Any help on that?
Old Jul 14, 2012 | 10:47 PM
98LineCook's Avatar
Never mind I found the DIY.
Why is it that when I spray wd40 under the brake pedal the switch seems to make contact and releases the shifter? I haven't opened up my shifter but I'm guessing a new brake switch will do the trick.
Also i have engine light on and Im getting egr and coolant sensor readings...are these expensive fixes?
Old Jul 15, 2012 | 11:18 AM
tempetom's Avatar
I had to change my brake switch a couple years back also. It's not too hard, but you do need to be a contortionist.
Old Jul 15, 2012 | 11:47 PM
98LineCook's Avatar
yea i found a DIY on here and I guess taking a couple of screws out of the bottom under the steering wheel opens up a lot more room.
did the brake switch fix the locked shifter for you?
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
joflewbyu2
Oct 8, 2015 11:16 AM
steve
Sep 30, 2015 09:23 PM
