Fan problem maybe???
Old Jun 19, 2006 | 01:17 AM
desired_speeds's Avatar
Question Fan problem maybe???
So we were heading to Sacramento from San Francisco today. We drove for 2 hours without stopping and the car did fine. That was until we got to our destination and turned off the car. I know that its normal for the fan to run for a little bit after you shut the car off. But 5 mins later, I came outside and the fan was still running, so I took it out for a little drive and the fan did the same thing and continued to run for over 5 mins after the car shut off. I ended up pulling the condenser fan fuse so it wouldn't drain the battery. I'm not sure if this is normal because the temperature was pretty warm in Sacramento, and 2 hours to continuous driving didn't help either, but is this a problem or is it normal? Thanks in advance!
BTW, the temperature was in the mid 80's when we got there.
Old Jun 19, 2006 | 07:42 AM
KrayzieDxC's Avatar
Khmer Pride
its normal to have the fan running..as if i take the car out for 20 mins it runs more then 10 -15 mins its ok just dont defuse it. it wont drain the battery either it takes little volt out of it
Old Jun 19, 2006 | 11:39 AM
TexasHonda's Avatar
My recollection from the shop manual is the engine-off cooling cycle is fixed at about 15 minutes. This feature insures that engine cylinder head does not overheat due to heat soak from the block when a hot engine is shut down. It helps to prevent head gasket damage.
good luck
Old Jun 19, 2006 | 02:50 PM
copy252's Avatar
normal IMO. another sweet honda feature i guess!
Old Jun 19, 2006 | 10:03 PM
Cool, thanks guys!
Old Jun 20, 2006 | 02:10 AM
Ken1997TL's Avatar
good luck
Yes, its 15 minutes
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
SidhuSaaB
May 30, 2020 12:40 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
flybyglass
Sep 24, 2015 01:12 PM
