Exhaust Manifold issues
I recently moved to Phildelphia and my 1998 2.5 TL with 165k miles failed the basic inspection because there is a crack in the exhaust manifold. I love the Acura but the mechanic said that the cost to fix is $4,400.
Does anyone know if I can get used parts in the PHL area or if you know a good local mechanic that knows this model well that might be able to fix it for me!
I love the car but cannot afford to spend money to fix it - If I could I would have upgraded to the latest TL!
Thank you all
Thank you all
Received 2,329 Likes
Junkyard. A cracked exhaust manifold shouldn't be more than $750
Brand new manifold installed at the stealership will not cost more than $1400.00.
Mine cracked last year. I bought one online for I think $300.00 and my mechanic charged $200.00 to install it.
You may qualify for the extended warranty, I am not sure.
Go here and and send out a request for a used one.
http://www.uneedapart.com/index.php
A skilled welder can perform a weld repair that will work. Stop-drill crack ends, preheat, and use of correct weld consumible should allow a good repair. Brazing may be a lower heat input option. I would find someone who regularly repairs exhaust manifold cracks and rely on their judgement.
Used parts are expensive ($300 and more), and might have the same flaw appear in short order.
I was able to get Acura to replace mine but car only had 95K miles when work was done. It's worth asking Acura for some help on this issue.
good luck
good luck
All about JDM
the 98 isnt covered under warranty unfortunately. i have a 98 and had to pay for that shit outta pocket. it didnt cost more than a $1000 though parts and labor with a new manifold. whoever quoted you that price is seriously trying to screw you over.
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
Billu99tl
09-13-2015 11:30 AM
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
