Engine stops at speed
Old Dec 9, 2006 | 07:32 AM
Northstarexec's Avatar
97 3.2 TL with 180k. Engine just stops at speed every 0.5 mile or so. All electronics continue to function. Car will eventually start. Replaced a totally plugged fuel filter. Fixed 99% of the stalls, but engine still cuts-out infrequently. The other night it cut out at 70mph coasted to about 20mph and then engine just started again - without engaging the starter (didn't touch the ignition key or anything else as I was too occupied avoiding getting killed on the Capitol beltway - scary)!
Will a plugged fuel filter damage the fuel pump? Does this sound like a coil problem (electrical) or a fuel problem. Thoughts and thanks!
Old Dec 9, 2006 | 07:50 PM
TexasHonda's Avatar
Problem symptoms suggest possible failing keyswith contacts allowing system to shutdown intermittently. You really need to understand whether stalls are due to loss of ignition (keyswitch) or loss of fuel pressure (bad main fuel relay, bad fuel pumpt, etc). A crude but effective check of fuel pressure is to crack the bleeder bolt on the fuel rail. If you get a spray of fuel, the pressure is probably OK.
When no start occurs, use a spare spark plug grounded to engine to check for spark. If no spark, the keyswitch seems likely.
good lu
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
PortlandRL
Sep 14, 2015 12:01 PM
Sep 14, 2015 10:48 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
