engine mounts on 2.5 replacement
Old Oct 19, 2005 | 07:04 PM
pi1996's Avatar
my front mount is busted on a 2.5 TL..
i want to ask you guys if its safe to lift the engine a bit with panels of wood and a jack at the oil pan..
any other ideas?
thank you.
Old Oct 19, 2005 | 08:10 PM
TexasHonda's Avatar
I would say yes. I have done this on 2.2L Accords a number of times to gain additional clearance for working on timing belts.
good luck
Old Nov 1, 2005 | 09:02 AM
nick96acuratl's Avatar
should be fine.. ive done it before dont over do it though
Old Nov 13, 2005 | 07:09 AM
smonster0516's Avatar
I need to know the procedure as well!
Old Jan 14, 2006 | 11:55 PM
pi1996's Avatar
well, i tried to take off my mounts today..
held the engine, removed the bracket from the mount to the engine.
but, couldn't get the mount out..
looks like i have to take out the axles..
has anyone done this?
i will try again later..
can anyone give me tips on how to separate lower ball joint safely for the rubber boot..
Old Jan 15, 2006 | 06:38 AM
TexasHonda's Avatar
Looking at shop manual, I think you'll need to temporarily remove the mid mounts and transmission mounts, while supporting the engine and trans w/ jacks to gain enough clearance to remove the front mounts. In the shop manual for engine removal, these are the last item released.
You need a shop manual to perform major work such as you contemplate.
Why do you thing the front mounts are defective? Are they obviously ruptured or sheared?
good luck
Old Jan 15, 2006 | 10:21 PM
pi1996's Avatar
my mount is definitely bad.. silicone has leaked out of it.. and the rattle is really annoying..
i looked at the manual..
i don't raise engine enough to clear the bolts on the mount, i just support it, so no need to take off the mid mounts..
the bracket that connects to the mount is attached to the engine by 3 bolts.. so i just take off the bracket..
in the manual, look at info on how to remove differential..
thanks.
Old Jan 19, 2006 | 12:46 PM
wildnphx's Avatar
3rd Gear
My mounts bad as well
I have not tackle this job yet but I need to replace all my mounts, How difficult is it?
97 2.5TL
Old Jan 19, 2006 | 09:15 PM
pi1996's Avatar
well, so far i changed the one on the passenger side.. it came out on the inside side of the frame.... will change the other one tomorrow.. i think i will have to take out the axle to get that one out..
i'll try to take some pics..
but so far my vibration is still there.. we'll see if changing the other one fixes it..
if it doesn't .. i'll be sooooo mad!!!
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
