Diy Egr Cleaning?
Old Mar 9, 2006 | 03:36 PM
romero_elvis's Avatar
1996 ACURA 3.2 ON RL 16'S
Exclamation Diy Egr Cleaning?
Does Any one Here have an idea what to do when cleaning the egr valve and passages? Is there thread that can help me do this i know where it all is and stuff i just need some guidance................thanks guys!
Old Mar 9, 2006 | 06:49 PM
TexasHonda's Avatar
Have you investigated the one-time emissions repair by Acura? Not sure if it's applicable to 96, but worth a check.
If you know where EGR and EGR manifold is located, it's a simple matter to remove, clean passages w/ throttle body cleaner and mechanical tools (stuff is pretty hard), and reassemble. I haven't done a 3.2TL, but have done a couple of 4-cyl Accords. The outlet holes into the intake manifold passages may be completely blocked and require cleaning w/a drill bit. The hole size may vary from hole to hole (balanced EGR flow sizing). You likely will need a new EGR and EGR manifold gasket. Best to get before you start. Presumably you have an "insufficient EGR flow" code?
good luck
Old Mar 10, 2006 | 11:20 AM
YEAH I HAVE THE CODE P0401 INSUFFICIENT flow and i went ahead and used your tips and actually not too much blockage but i am going Champion Acura here in Houston And they said that that item was covered under the emmisions extension plus i already had them do the tsb for my vehicle oil, plugs and filter nothing major but i didn't have my check engine light on at the time
Old Mar 12, 2006 | 11:43 AM
TexasHonda's Avatar
If cleaning the ports didn't clear the code, you probably have a defective EGR. Other EGR faults set different codes. Time to let Acura do the emssions repair since an EGR is probably close to $200.
good luck
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
