Cranks for a long time when starting cold. Great, what is this?
My car cranks like 15 times before starting. Sometimes I have to turn the key back then try again. Is this the spark plug wires?
it could be a simple tune up... sometimes think oil may cause this problem as well.
check spark plugs wires and distributor.
turn ur key and wait 3 seconds before cranking... sometimes when i start crancking right way it won't start for me either.. so i usualy wait for my fuel pump finish initializing.
Registered Driver
Received 2,329 Likes
Turn the key to II, let the fuel pump do its work and then go.
In other cars that I have owned, when you have to run the starter for that long it was usually an indication that the coil was going bad. Just my 2cents. Also you should never run the stater for that long that is generally the fastes way to burn them up.
Ahh. Thanks, thats what I was looking for. I had a suspicious feeling about my coil anyways. Much appreciated.
Dustin.fagin@comcast.net
www.InspireCarAudio.Com (under construction.....still)
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
darksky
09-05-2015 03:11 AM
