Coolant level little above Minimum
The coolant level in my TL is a little above the minimum mark. Should top it off or flush and refill? My dealer said that since my car has 58000 miles on it, it is better to flush it off and refill.. Charge $ 195
![what](https://acurazine.com/forums/images/smilies/what.gif)
Registered but harmless
Received 1,106 Likes
The flush/replacement is service 5 in the Maintenance Minder-- which probably means @ change of timing belt (service 4) and water pump, usually around 100K miles.
Oh, and this thread should probably be in another section, like the main 3G TL page, rather than here in "Tires, Wheels..."
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
About refilling, you can top off with distilled water. It's only a few ounces, won't hurt anything by diluting it with a few ounces of water in a 2 gallon system.
I recommend a drain and refill now but I believe the first recommended flush is 105,000 when you do the timing belt.
I do it when the timing belt comes along. Main reason why whenever you change the water pump you pretty much drain the cooling system anyway so why not do it then thats how I see it.
You can run the Honda antifreeze mix or you can top off with distilled water. It really doesn't matter in such a small amount. The water gets cycled everytime the car is heated and cooled. When it gets hot, coolant flows into the tank and when it gets cool, fluid flows out of the tank so it all gets mixed in quickly.
Top it off for now.
Oh, and this thread should probably be in another section, like the main 3G TL page, rather than here in "Tires, Wheels..."![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Yea, but what is it doing in 1G TL?
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
ExcelerateRep
10-14-2015 08:20 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
4drviper
09-23-2015 07:42 PM
