White smoke from exhaust
Old 04-18-2010, 12:13 PM
7th Gear
w5draw's Avatar
Hello everyone: I am starting to see white smoke coming from my exhaust from my rear view mirror after I press on the accelerator when I have to stop. Does anyone know what causes this?
w5draw
Old 04-18-2010, 12:15 PM
7th Gear
w5draw's Avatar
I forgot to tell that the car is a '96 TL 3.2 engine. Thanks.
Old 04-18-2010, 07:46 PM
tmnhs81's Avatar
Is car over heating? Are you loosing any oil? How does it smell?
Old 04-18-2010, 07:47 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
If it's thick white smoke, you might've blown the head gasket.
Old 04-18-2010, 08:15 PM
'13 Hyundai Sonata
TLin401's Avatar
You have bad valve seals.
Old 05-17-2010, 01:35 AM
9th Gear
Brwn28875's Avatar
Im going through the same thing with my 2.5 tl. Just started. Is the smoke white or blue? White smoke is probably a blown head gasket. Blue smoke is oil. If its only smoking after letting it idle, it sounds like bad valve seals. Getting ready to rebuild the head on mine and see what happens. I'll let you know.
Old 05-17-2010, 08:16 PM
desired_speeds's Avatar
any oil consumption problems? coolant level dropping at all? Has the car ever been overheated?
Old 12-11-2012, 12:41 AM
Yout Yang's Avatar
fixed the head gasket. fix the over heating but still smoking out too much. what can it be. piston rings
Old 08-06-2014, 10:11 AM
7th Gear
w5draw's Avatar
Well, my car runs fine. It does not overheat, but does burn a quart of oil a week.Smoke really flairs from exhaust pipes after idling at stoplights. Thinking about hanging a barbecue sign on window.....seriously though, do you think it is the rings. Should i try heavier weight oil? Thanks guys, you are the best. I love this car and this site and would hate to part with both.
ruby rose (04-26-2023)
Old 08-12-2014, 08:09 PM
9th Gear
Problem2.5TL's Avatar
W5draw I have the same problem smoke after idle is your valve stem seals I haven't got around to doing mine yet but seems pretty straight forward doing it when I do head gasket all that fun stuff at 195k or so was last done at 110k
Old 06-08-2019, 12:06 AM
Brad Bunger's Avatar
Similar problem here. Acura 2005 153K White smoke out of exhaust , engine light on, coding bank 1, sensor 1 O2 code with multiple misfires on all cylinders. Not overheating, no “sucking sound” like a head gasket. Oil and coolant looks clean, haven’t added oil, haven’t added coolant, no leaks present, took to dealership and they ran a compression check and it passed, found bad spark plug in cylinder 1, replaced the plug, running better, but rough at initial idle. Any idea?
AJ_Acura04 (10-03-2022)
Old 06-08-2019, 06:34 AM
Received 16,260 Likes on 11,971 Posts
okay, it's going to be hard to troubleshoot...because you're all over the place..
is the car currently throwing any codes? if so, fix that first. if it's calling for the 02 sensor, fix it.
what were the compression numbers?
how did the plugs look?
are the coil packs good?
are you sure no mix of coolant and oil?
Old 06-28-2019, 12:48 AM
Okay, Acura in Little Rock did not fix my car. The O2 sensor is fixed, still getting misfires on cylinder 5 and 6, after replacing plugs and packs. White smoke and gas smelling at exhaust, slight white smoke. Car not overheating. Now, car is starting slowly. I’m lost, lol. ICM? Bad wiring? Head gasket? Just not sure. Not sure about compression, but plenty of power.
hashbrown
02-18-2022 11:20 AM
Jimmy_D
10-07-2015 11:52 PM
jmaxima03
09-27-2015 10:22 AM
prbori
09-27-2015 01:37 AM
Quick Reply: White smoke from exhaust
