Code p0133
Old Aug 2, 2006 | 08:11 PM
BUGLITTER's Avatar
Code p0133
Hi,
I try to troubleshoot this problem by replacing the O2 sensors and clean out the fuel system but it doesn't seems to help, check engine light still come on after around 30 mile driving. I just replaced the MAP sensor to fix another code.
It's a 98 TL 3.2 99+k mile on.
Any help will be appreciated
Old Aug 2, 2006 | 08:26 PM
KrayzieDxC's Avatar
Khmer Pride
check this.
http://www.obd-codes.com/trouble_cod...1-sensor-1.php
Old Aug 3, 2006 | 08:32 PM
TexasHonda's Avatar
It's usually best not to chase multiple codes at same time.
What is other code? Perhaps they are related.
P0133 could be several things, but must not have been a bad sensor.
If you have a 2.5L engine, you should check for a cracked exhaust manifold as this is a very common problem and could lead to O2 sensor errors.
For best help, add you vehicle description; year and engine to your signature.
good luck
Old Aug 3, 2006 | 09:03 PM
KrayzieDxC's Avatar
Khmer Pride
he already stated it s a 98 3.2tl..but aint map sensor is emission? it should be but try askin them if they do warranty on a 1998
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
