Code p0133
Code p0133
Hi,
I try to troubleshoot this problem by replacing the O2 sensors and clean out the fuel system but it doesn't seems to help, check engine light still come on after around 30 mile driving. I just replaced the MAP sensor to fix another code.
It's a 98 TL 3.2 99+k mile on.
Any help will be appreciated
Khmer Pride
It's usually best not to chase multiple codes at same time.
What is other code? Perhaps they are related.
P0133 could be several things, but must not have been a bad sensor.
If you have a 2.5L engine, you should check for a cracked exhaust manifold as this is a very common problem and could lead to O2 sensor errors.
For best help, add you vehicle description; year and engine to your signature.
good luck
good luck
Jamus22
06-11-2023 10:08 AM
