CEL again WTF!!
Old Mar 29, 2010 | 02:45 PM
7 Tl's Avatar
CEL again WTF!!
I washed the tl today a little detal here and there. Turnrd it on and i saw the damn CEL on again. About two and a half months after cleaning out the egr pipe and intake manifold idk whats wrong.... BUt the trippy thing was, that as i backed up out of my drive way had the car in reverse (duhh), it started to kinda shake and bam she turned off on me. ANY ideas, or thoughts guys?????
Old Mar 29, 2010 | 03:03 PM
tmnhs81's Avatar
Scan the CEL first.
Old Mar 29, 2010 | 03:05 PM
7 Tl's Avatar
^ i am, i was thinking low fuel pressure but no.......
Old Mar 29, 2010 | 03:08 PM
tmnhs81's Avatar
What code did u get?
Old Mar 29, 2010 | 03:39 PM
Mandy's Avatar
98 3.2 Flamenco Black
Scan and then clear it up. Have a reader? It is a very valuable tool for us guys who have aging TL's. I am not complaining about our TL's.
People still scratch their heads.
What year is you Acura? What kind is it? I thought that was an RL....
Old Mar 29, 2010 | 03:45 PM
tmnhs81's Avatar
Don't clear the code out. If you are gonna take it to some mechanic to get fixed then dint clear the code. The saved data is helpful when diagnosing.
Check the code first. Assuming isn't going to get you anywhere.
Old Mar 29, 2010 | 06:02 PM
Go90go's Avatar
大日本帝国
Write the code down, clear it, then see if it comes back. Sometimes codes just pop up and they don't necessarily mean anything's wrong.
~Cheers~
Old Mar 29, 2010 | 06:16 PM
7 Tl's Avatar
I havent had time to check the code out i dont have a scanner of my own so ill take the tl to autozone A.S.A.P.....so far it seems to drive fineso hopefully nothing major
Old Mar 29, 2010 | 10:00 PM
7 Tl's Avatar
no codes yet....but i found out what it should be....i drove to target about 30 mins ago and as i tried to start the car back up There was no click. The car wouldn't start untill about an hour later...
Im pretty sure the problem has to do with something electrical because not so long ago my left headlight went out about two times already since i've owned this car every time i wash my car. "something under the hood must be getting wet"....
Old Mar 30, 2010 | 08:25 PM
tempetom's Avatar
I had an intermittent no clink then start for about a year on mine. I replaced the ignition switch (electrical part) but it still did it. Finally replaced the starter (ugh) but it stopped it. If you live in Phoenix, I know exactly how to change the starter. I learned it all the hard way.
Old Mar 30, 2010 | 08:51 PM
myisanog's Avatar
if you drive a 1g tl and you change your own starter ... props to you . too much work for me
Old Mar 31, 2010 | 01:31 AM
Go90go's Avatar
大日本帝国
^ It IS a pain in the butt... And hand, and forearm.
~Cheers~
Old Mar 31, 2010 | 02:11 AM
desired_speeds's Avatar
what? 20 mins to pop the axle out with hand tools.
Old Mar 31, 2010 | 07:28 PM
7 Tl's Avatar
Would a bad alternator/ starter give me a cel????
Old Mar 31, 2010 | 07:40 PM
tempetom's Avatar
I agree that I could remove a driveshaft pretty fast now, but the first time you do anything it takes some time. I've never even thought about removing a driveshaft on a front wheel drive car before. I also was reluctant to use a pickle fork on the lower ball joint that has to be separated before taking out the shaft. I drove all over town before finding the proper tool. I still think Honda should have used socket head cap screws to mount the starter, and if I ever do it again, I'll special order both (at least the rear one). That would really make the job easier. As Go90go said on another thread, you don't have to remove the exhaust pipe to do it.
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
