Brake time.
Brake time.
Well fellas i dont know why but my brake light comes on randomly (The you have a bulb out light). I checked threads & got the idea of topping off brake fluid which i know is not at max currently. But anyways when you guys have changed your brake pads what is the best pads to get in your opinion & expirience with the TL? I'm definetly going ceramic but would apreciate your advice.
Thanks.
Thanks.
OEM pads are hard to beat. Check ebay for a good deal.
I've had an intermittent bulb cause the bulb-out light to come on. Replace bulb and see if that helps. Filament is cracked and opens momentarily causing the light to be set (that's the theory anyway).
good luck
good luck
Just bought O'reily's ceramic brake pad for $39.99 made in the U.S.A. these pads the definitely worth your buck lasted me a long time. But keep in mind to get the full effect of nice brake feeling I also got brand new rotors all around.
SidhuSaaB
05-30-2020 12:40 AM
GWEEDOspeedo
01-15-2016 10:39 PM
