Bad Smell from AC
Old Jul 9, 2009 | 08:59 PM
levelfamily's Avatar
levelfamily Ent.
Bad Smell from AC
hellos guys, I have a problem with my car AC, since i start the AC during 3 or 5 seconds, there is a bad smell like humid or something else, I went to autozone and ask how to fix that, they said check the cabin filter but my 97 TL 2.5 don't used that, how can I fix this S>H>I>T ? ? ? ? ? ? ? ? ?
Old Jul 10, 2009 | 08:39 AM
levelfamily Ent.
damn, nobody is gonna help me how to fix this problem. ? ? ?
Old Jul 10, 2009 | 09:02 AM
DarkSithCL's Avatar
Be Strong AND Courageous!
call ur local acura dealer... they should be money on that.... but then do it urself
Old Jul 10, 2009 | 09:04 AM
DarkSithCL's Avatar
when I had a funny smell in my 2001 cls... i cleaned the intake area around the windshield with the hood open... there was a buncha pine needles there.... smell went away after that...
Old Jul 10, 2009 | 09:39 AM
levelfamily Ent.
thanks i''ll try that.
Old Jul 10, 2009 | 10:00 AM
tmnhs81's Avatar
I have same issue and Its "normal" with 1G TL's I believe. It comes with slow(windows) and stinky(AC) package...lol
Old Jul 10, 2009 | 02:34 PM
Mandy's Avatar
98 3.2 Flamenco Black
We did not have the cabin filter...so, it stinks. I just use car freshner....but it still stinks...
The only other way is to get the evaporator cleaned of mildew. That means the the whole AC unit has to come off...sucks!
Old Jul 10, 2009 | 02:57 PM
desired_speeds's Avatar
next time when you're about to turn off your a/c, the only the fan run for a minute before turning everything off.
Old Jul 10, 2009 | 03:09 PM
Go90go's Avatar
大日本帝国
^ That works. Anyhow, try spraying Lysol along the vents in the cowl, while running the fan. That should kill any mold/mildew build up from the condensation.
~Cheers~
Old Jul 10, 2009 | 06:45 PM
TexasHonda's Avatar
I removed the condensate drain line on pax side center tunnel (easy access), and flushed evaporator w/ air pressure driven mildew-cide (consan) and a weak bleach solution. Let sit for 1-2 hrs, and flush w/ clean water multiple times. Flushing procedure is to air pressure drive the water into the evaporator, and use shop wet-vac to suck the water back out. It seems to have helped. Howver, I agree w/ other poster this design is prone to bad evap smell.
I also sprayed lysol in the vents as suggested.
good luck
Old Jul 11, 2009 | 02:06 PM
TLin401's Avatar
'13 Hyundai Sonata
Does it smell like something is burning? I had this same problem and it ended up being that my crankshaft pulley had broken.
Old Jul 12, 2009 | 06:49 PM
levelfamily Ent.
i did spray lysol on the vents with my hood open, the bad smell is gone, but now all my boys tell me to spray fabuloso because the car smells good but smell like a hospital, 'cause i used lysol concentrate.
Old Jul 13, 2009 | 10:07 AM
main70072's Avatar
I leave my fan running on lowest speed with the a/c off most of the time. No smelly problems.
Old Dec 15, 2009 | 08:14 AM
wrensu's Avatar
I have a bad chemical smell when the air starts blowing. I have to open the windows. The dealer said this is a common complaint and they do not know what to do about it. I have a 2008 MDX.
Old Dec 16, 2009 | 07:07 PM
TexasHonda's Avatar
Later models such as yours have an fresh air filter which greatly helps to keep evaporator and heater core clean. However, the filter gets dirty and needs replacement every 1-2 yrs.
good luck
Old Dec 16, 2009 | 11:07 PM
TLin401's Avatar
'13 Hyundai Sonata
It is very easy to replace.
You just need to remove your glovebox and the filter is there for your access.
Old Dec 16, 2009 | 11:17 PM
tmnhs81's Avatar
This had me wondering if 1G TL's have a cabin air filter??
Old Dec 16, 2009 | 11:33 PM
TLin401's Avatar
'13 Hyundai Sonata
No we don't have one.
hrothgar02
Nov 2, 2015 01:29 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Timmy18
Oct 17, 2015 03:58 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hrothgar02
Sep 28, 2015 11:08 AM
