alignment
Old Aug 8, 2006 | 09:36 PM
pi1996's Avatar
alignment
i have a question..
I've replaced my front sway bar bushings and tie rods..
I was careful about matching the threads.. to the way they were originally..
i also replaced the rear bar bushings..
so, do i need an alignment?
what are the rules regarding this?
Old Aug 9, 2006 | 01:13 AM
Ken1997TL's Avatar
When was your last alignment?
You should be ok if you installed it correctly.
Old Aug 9, 2006 | 09:48 PM
pi1996's Avatar
well, i had the alignment done..
the car doesn't feel so loose anymore..
i have made a mistake of not tightening the adjustment bolt at the pitman arm..
however, i have replaced the bushings on the front sway bar(center and endlinks).. and I have tightened the bolts when the car was up on jacks..
i read in the manual that i must tightend bushings down when the car is down.. is that right?
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
