alarm system malfunction
Old Aug 22, 2009 | 04:46 PM
Franknitti's Avatar
4th Gear
Question alarm system malfunction
Were's the hood switch located someone said if i disable it the alarm wont arm then i'll be able to start the car can someone help?
Old Aug 22, 2009 | 04:53 PM
J23's Avatar
J23
sounds like you're trying to steal that car hmmmm?
Old Aug 22, 2009 | 05:07 PM
Franknitti's Avatar
4th Gear
Ican't steal whats mine
My fuse keep blowin sometimes it won't blow then i'll be able to disable the alarm with the key.l think the drives door lock is malfunctioning sometimes it will disable with the key.I put a 5 amp fuse in it an it worked for like a day and went back out. I just need to know how to disable it.
Old Aug 22, 2009 | 09:05 PM
Go90go's Avatar
大日本帝国
Unlock from the passenger side for now. Until you find out WHY it's blowing fuses, I wouldn't try to disable anything else. That's why the fuse is there.
~Cheers~
P.S. Shouldn't it be a 10A anyway?
Old Aug 22, 2009 | 10:47 PM
TLin401's Avatar
'13 Hyundai Sonata
If its the factory alarm then you can disable it from the passenger's side. I believe the relay is on the passenger's side of the radio in that area.
Old Feb 15, 2010 | 06:37 PM
theTLer's Avatar
8th Gear
I have a 01 TL and I use my keys (not remote) for opening closing the car.
My car alarm goes ON suddenly/randomly ...It won't stop even if I start the car...
any ideas ?
The alarm goe OFF wfter atleast 2-3 minutes....it is pain...any ideas..
Old Feb 15, 2010 | 08:37 PM
TLin401's Avatar
'13 Hyundai Sonata
Pull the relay for it. Then it will shut off.
I am unsure where the relay is in a 2G but that should solve the problem.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
