Air conditioning noise...
Old Mar 21, 2011 | 01:49 PM
9632tl's Avatar
Radical Member
Today I noticed a grinding noise while my car was idling. It sounded like a dry bearing. The sound got worse after the ac pump cycled on and off. Then it would get a little better until the pump cyled again. It didn't make noise while the pump was going. I also noticed that the compressor was still spinning (very slowly) when it was not engaged. Is that normal?
While driving, I could hear the pump kick in a few times. It sounded bad. Like the clutch was slipping. Didn't sound like a belt.
Has anyone else had problems with their ac pump/clutch? Any ideas on isolating the problem? I don't want to replace anything more than absolutely necessary. The clutch alone is over $200 :/
Old Mar 22, 2011 | 10:28 AM
tuanrich's Avatar
Could be the belt tensioner bearing. It's cheap to just replace a bearing (about $15 from NAPA).
Old Mar 22, 2011 | 01:18 PM
9632tl's Avatar
Radical Member
It wasn't the bearing. I replaced that today. There is now grease coming from the ac clutch hub, and the pump isn't working. Im hoping its just the clutch.
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
rcs86
Aug 2, 2016 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
