1998 Acura 3.2 TL Headlight Bulb Replacement
My passenger side headlight bulb went out. I don't want to go to Acura to have them fix it NOR do I want to order parts from them. Where is the best place for me to order some new bulbs (if I have to order a driver-side bulb to make them the same, I will) and how do I do the actual replacing since I have never done it myself?
first let me welcome you to the forums...
as for the bulbs, you can replace it with any halogen bulb unless there are different bulbs in there... but let me warn you, the passenger side is a pain in the butt.. u basically have limited space to work with and need to maneuver the bulb through the bracket that holds the power steering resevior... it is just in front of the air filter housing...
Very Easy To Do, U Going To Have To Buy A 1 Pair Or Each I Think ,anyways. Just Make Sure You Dont Touch The Bulb Glass Or U Blow It..the Passenger Side Is Hard But Replacing Your Corners Light Is A Pain In The Ass
Mike Bertram
Sep 10, 2015 09:27 AM
asahrts
Sep 4, 2015 05:55 PM
