1997 Acura 2.5 TL Vehicle Speed Sensor
Subscribe
Jan 30, 2015 | 10:10 PM
Hi everyone, sorry to bother again!,
I'm having an issue with my V.S.S in my 97 acura 2.5 TL
Diagnostic codes: P1791 / P0700 / P0500 / P0135 ( which is o2 sensor a totally different issue I'm guessing )
Issues that are noticable by me: No Speedomter / odomoeter / trip counter
Could someone please link me to the correct parts
( oem or replacement without much side work to be done)
I've checked a the forum posts, there's a few guides and other people having the same codes / issues, but I'm truly a novice, a direct link to the part(s) I need would be a great thing you could do for me, as I've looked around and don't have the time to ship back if I fail , I have a 20-30 mile trip 3-4 times a week to take and are trying to get this done asap! I have an experienced mechanic but he's not comfortable with electrical work and or rebuilding parts ( as noted in TexasHonda's post, and we both feel we might waste time / money / and be worse off than we started.
Please help asap if you can! Thank you so much!!
Reply 0
Jan 31, 2015 | 12:17 PM
1997 Acura 2.5 TL Vehicle Speed Sensor Location Also?
Also if you could give a detailed explanation of where the V.S.S is located and or a picture that would be great, I see a few sensors around the area where we think it's located, but not entirely sure.
Thank you so much everyone!
~Chris
Reply 0
Feb 3, 2015 | 11:16 AM
Found the location exactly! Noticed that the ground wire was the only wire in the pigtail.. the other 2 had been forcefully pulled out when the last shop did an oil filter change.. HOW RUDE! I simply put the 2 wires back in, unhooked my battery ( to clear the error codes since I don't own a diagnostics machine) hooked my battery back up and BOOM! we have a sensor working again, even fixed my cruise control . TY ALL!!!! hope This can help someone in the future!
Reply 0
Feb 12, 2016 | 11:14 PM
Help?
There located next to the calipers . I have the same problem ! I ordered the new sensor but my question is how can you tell which side needs the new sensor ?? There's four . one on each side ..
Reply 0
Subscribe
