want more power under the hood
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
im no car genius and im looking for suggestions to get more power out of my 97 tl. any suggestions for engine swap? turbo? or maybe supercharger? just looking for some ideas.
大日本帝国
Well, first things first: what version do you have? One of the best NA mods period (as in bang for the buck), would be an intake. Do the regular tune-up/maintenance stuff with it, i.e., oil change, spark plugs, and it'll already be noticeable.
~Cheers~
P.S. Welcome!
~Cheers~
P.S. Welcome!
you got a 2.5 or 3.2? i can imagine the 3.2 is pretty quick (i got the 2.5), but i hear some people complaining how the 2.5 is slow.. but i can say 1st hand that proper maintenance will make a huge impace on the abilities of your ride.. for me simple things made huge difference as Go90go said spark plugs, wires, oil change (rislone really helps!!), trans flush, differential flush, air filter, tire pressure, and some people don't agree with this but seafoam..i can say 1st hand that it worked great on my car..
seafoam- bg44- wynns- something is better than nothing
Engines- especially now with more ethanol in the gasoline, are
high revving mobile crud factories - each combustion cycle leaving behind unburned fuel- burn residue and byproduct- oil vapors
I need to post some pics of an engine I have the heads off- carbo city- would take a scraper tool to get just some of it off
for those worried about seafoam read their website- same product in use since 1940, they keep finding more uses for it
first time foamers shoud repeat the vac port and gas tank method after 2000 miles-then good for a year
Make SURE you are using the vac port right at the intake manifold- it will be the only larger than normal size vac hose with a clamp on it! remove that hose- feel ~20 psi suction- thats the place- will clean the system well from there
USE seafoam in its aerosol spray can version - sold as `Deep Creep` - its 100% seafoam - same amont same price- just way easier to put in the vac port or, thru carb if applicable to your vehicle
a clean engine is a happy engine- clean the oil method too, and then some new NGK platinum or iridium spark plugs- should run way better
If cap and rotor equipped- check those
Your Friendly Canadian
Received 1,485 Likes
seafoam, intake, fluids, as well as maybe a throttle body spacer if one was possibly made for the 1g TL.
I've been looking online, is there a K&N cold intake for the 2.5? or is that weapon-X dragon the only brand? I'm looking for a short intake, I do not wish to lose versatility. I desire a reliable brand name, such as K&N.
Has anyone done a 5 lug conversion from the 2.5 to 3.2 wheels? This is one of my goals, along with eventually downgrading my engine (possibly to a 2.0 I4? or some other engine which could reserve more gas but be modern enough to give more umph)
how much would you have to spend on the engine swap to offset the diff in fuel prices you are paying??? there are plenty of ways of saving gas and just because you switch to a smaller engine, it may even burn the same or even more gas because it is less efficient than what was designed for the weight and size of the TL...
did honda even make a 2.0L for the USDM market?
intakes are simple man, you dont need to spend a lot of money to have good intake, and if you dont care about its looks too much you can even make one pretty easily.
大日本帝国
大日本帝国
Decent price, little gains, expensive to have someone install, pain to do it yourself.
~Cheers~
They have them for the 3.2s, under 91-95 Legend. The thing is, the OBX is based on the Type II Legend's factory setup, so the Y-pipe is equal length with two flanges visible from under the car, whereas all the other 3.2s and 3.5s have an extra mid-pipe on the right (facing the front of the car) side.
~Cheers~
~Cheers~
its a product thats about $7 that some auto part stores carry. YOu suck it into your intake side of the engine and turn off the car and let the formula work to clean out the carbon buildup inside. then you start the car and rev and drive around to burn all the carbon that the seafoam as removed from the engine.
i let it sit for 10 minutes.. then drive til all the smoke goes away.. i recommend changing spark plugs, i didnt change them after.. they were new plugs, this morning (2 months later) i changed them to iridium, but all the 3 month old plugs were foul.
Are iridium plugs the best?
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
