Positive / negative switched
2007 6SMT Type-S
I gotta be sure the '96 3.2TL Premium is neg/pos or else the wire harness I'm gonna get won't work. If you're sure, I'll order it today. Thanks for the quick response, fellas.
2007 6SMT Type-S
I meant to ask you this a LONG time ago, but what projectors are you using in your set-up. Also, did you make your own HID harness or did you purchase it. If you bought it, have you any issues?
大日本帝国
~Cheers~
2007 6SMT Type-S
How's your output with your after-market projectors? I'm using e55's and my output is just okay.
Can you recommend anyone/site for a wire harness? Mine only last like 25 hours and that's B.S.
大日本帝国
~Cheers~
2007 6SMT Type-S
I'm not totally against a little glare. The cut off doesn't look as nice, but it will help light up street signs.
Not sure what D2S to amp is. I am running D2S bulbs. I'm using an aux switch for my bixenon solenoid and I'd like to integrate it back into the stock headlight switch on the steering column.
大日本帝国
~Cheers~
2007 6SMT Type-S
I see. Actually my glare is so minor that there practically isn't any unless you're standing in right in front of the car. I might have something for you. Let me dig it out and check, as I've got 5 or 6 harnesses and harness parts just packed up and sitting in my room and the garage.
~Cheers~
~Cheers~
2007 6SMT Type-S
I'm sure I could, I just don't understand the relay part of the harness. I don't know what to connect to what.
30 - Hook this up to the fuse holder then to the battery
85 - One terminal of the OEM bulb harness (Positive or negative)
86 - One terminal of the OEM bulb harness (Positive or negative)
87 - Goes to the power source of the ballast
87A - empty
30 is the power source (battery)
85 & 86 are the positive and negative for the switch, so when you turn on your headlights it'll connect the power source from 30 directly to 87
87 & 87a are the 2 power outlets for the relay and the switch alternates it in between the two.
What I normally do is connect 87 to the power wire of the ballast and then use the ground wire on the ballast and connect it directly to the chassis.
2007 6SMT Type-S
I don't think anyone has ever explained it like before. Thanks, LDH. One final question: Is it better to go from a thicker guage wire to a smaller (i.e. 12 guage from battery to 16 guage on the ballast) or visa versa? OR is it best just to keep the same size wire?
I just used whatever I had. I used 12 awg all around for mine because that was what I had available. I'm not sure if there is a negative effect for mismatching wire sizes, but the OEM ballast wires on my denso ballast are pretty thin in comparison to the wires on my relay harness.
2007 6SMT Type-S
2007 6SMT Type-S
A Bosch Relay has 5 prongs.
87A - empty
87A - empty
Question #1: 85 & 86: I don't know which wires are positive and negative that come out of my male H4 connector. I guessing that if I interchange them, it'll effect if the lights come on in either the high or low beam position, correct? My main question is, will it do damage if I interchage them?
Question #2: I have just a 4 prong relay. Can I combine the power for both ballasts into one prong (87)?
Question 1
Positive and negative won't matter for 85 & 86 as long as there is 1 positive wire and 1 negative wire. With an H4 harness there are 3 wires: Positive, Negative low, negative high since hondas are negatively switched.
Positive + Negative low = low beam switch is the on position (you want this one)
Positive + Negative high = high beam switch is the on position
Negative high + negative low = nothing
Question 2
Yes you can run both ballast off of the 87 prong. You could make 1 relay harness per ballast, but that isn't necessary.
Question 2
2007 6SMT Type-S
Thanks a lot for your help, LDH! Any idea why my old harness would stop working so soon, or stop working at all? I noticed the harness was very hot when my passenger side stopped working. J/W.
2007 6SMT Type-S
I finished it up w/o any issues. I know it's best not to use crimp connectors but trying to solder 12 guage wire is a pain in the ass....and fingers. Hopefully this time the harness will last more than a couple months.
My current harness worked for 2 years on my accord before the fuse holder got ripped apart when installing it in my SC300, but with the new fuse holder it has been fine for 16 months in the SC.
2007 6SMT Type-S
I thought that heating the wires up too much wasn't a good idea. I mean, obviously it wasn't in your case. Maybe that was just if they're hooked up to other electronics...?
I must have just bought a cheaply made harness. Live and learn, right?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
xsilverhawkx
09-28-2015 06:51 PM
MrHeeltoe
09-28-2015 05:43 PM
