OBDII to ODBI Jumper
Old Jan 3, 2010 | 10:13 AM
memphisraines26's Avatar
thought this topic would be best for performance than general threads. (move back to general if need be)
Has anyone ever used an OBDI ecu with a OBDII to OBDI jumper harness to tune, bypass EGR, etc? I'm starting my long train of thought for when I get my 96 2.5 back so I can start the repairs and mods. I'm thinking trying to use the OBDI Vigor ECU to run a 5spd. Plus the same treatment I'm doing to my del sol with a wire tuck, brake tuck, ditch ABS, and shaving the bay. Plan to keep stock interior but focus on performance and suspension.
Old Jan 3, 2010 | 11:30 AM
TLin401's Avatar
'13 Hyundai Sonata
Someone had tried that before. He wanted to convert his car from OBDII to OBDI to do this swap but also wanted to convert OBDI to OBDII. He had someone doing all of the work for him and was told that it was successful on his 1G but on the vigor it was not.
So it is possible.
Old Jan 3, 2010 | 03:23 PM
yeh there is more to it being a OBDII. I kinda know some of the difference's in the OBD0 vs OBDI but have ways to go. I have a concept and trying to learn what I need to do to make it happen.
If successful in this part of the plan and get the 5spd to work, phase 2 will blow you away.
Old Jan 11, 2010 | 03:33 AM
Ken1997TL's Avatar
You can run the Vigor ECU, you'll need the harnesses from the Vigor though and OBD-I setup.
Old Jan 11, 2010 | 04:49 PM
you mean complete engine harness? what other things are OBD-I that I will need?
This should prove to be an interesting project...
mada51589
Jan 9, 2025 04:40 PM
bgsrmyth
Jan 23, 2006 03:25 PM
Smitty
Sep 29, 2003 10:25 AM
KavexTrax
Dec 11, 2002 10:26 AM
NOVAwhiteTypeS
Jul 8, 2001 02:18 PM
