Lighting help
Lighting help
Hey everyone,
My name is Ian and I have a 98 2.5, black on tan with a fresh factory respray, anyways.. I NEED to change my interior bulbs to L.E.Ds, I know for the cluster I need 5 194 and 2 74, but what about the hvac controls, gear indicator, courtesy lights, dome lights, the little trunk lights and the license plate lights? I did a little bit of searching but it was unclear, also, if anyone can tell me which bulbs exactly i'll need, that would be GREAT!!!!
Thanks,
Ian
Thanks,
Ian
Khmer Pride
High & low beam headlamp
9003/HB2
9003SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9003ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9003EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
168
168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
7440
7440ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
7440LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear turn signal
7440
Tail light
7443
7443ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
7443LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Stop light
7443
High mount stop light
7440
Fog/Driving light
64146BC
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
168
Map light
DE3022
DE3022LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
DE3021
DE3021LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
DE3021
Trunk/Cargo area
168
9003/HB2
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
7443
Stop light
7443
7440
Fog/Driving light
64146BC
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
168
Map light
DE3022
Dome light
DE3021
Step/Courtesy light
DE3021
Trunk/Cargo area
168
X-LAX (12-24-2012)
Lights
Hey try this site out it had all the LED info also....
http://www.modifiedlife.com/1998-acu...-size-diagram/
大日本帝国
can you just swap to leds in the instraments??? in my supra it was apain cause the clear things that carry the light didnt work well with leds, it would cause hotspots and low light areas because the leds are more directional.
大日本帝国
~Cheers~
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
