Who changed timing belts themselves??
The dealer wants like $600 bucks to change the timing belt and water pump. Does anyone here works on your car 95% of the time or go too the dealer? I want to change it myself but need to know if I need any specialized tools to remove things...
dayum, wassup ddub! long time no see (its me mark..the one who bought your rf amp long time ago). you should post here in the 1st gen more often. you could help out on your imput on questions.. see ya around
the timing belt isnt too hard
if you mark everything and put it right back together than you shouldnt have a problem. usually the hardest part is getting the crank pulley off.
but then again if you dont have automotive experience than i would not do it if i were you
you know what you can and cannot do. use your own discretion.
also having the right tools is the best advice i can give you
If you don't want to pay the dealer prices, your best bet is to buy the parts online somewhere, and have your local mechanic install it. Your warranty should be all used up when it's time to replace the timing belt and water pump.
asahrts
09-04-2015 05:55 PM
