what major engine tuning is required?
i am reaching almost 60,000 miles and i was wondering what major mechanical engine tuning is needed, such as re-adjusting valve timing (does this exist for a 2.5?), etc?
Hope this helps:
3,000 MILE CAR CARE SERVICE 15,000 MILE CAR CARE SERVICE
Replace Engine Oil (Done Also at 45,000; 75,000 Miles)
Install Genuine Acura / Honda Oil Filter Includes Complete 7,500 Mile Special
Check all Fluid Levels - Replenish if Necessary Plus the Following:
Lubricate Door & Hood Hinges Adjust Rear Brakes and Parking Brake
Check Tire Pressure and Adjust if Necessary Replace Transmission Fluid (automatic only)
Inspect and Clean Battery Terminals Adjust Valves to Factory specs.
7,500 MILE CAR CARE SERVICE
Replace Valve Cover Gasket
(Done Also at 22,000; 37,500; 52,500; 67,500; 82,500 Miles) Road Test Vehicle
Replace Engine Oil Balance Two Front Tires
Install Genuine Honda/Acura Oil Filter
30,000 MILE CAR CARE SERVICE
Check all Fluid Levels - Replenish if Necessary (Done Also at 60,000; 90,000; 120,000)
Lubricate Door & Hood Hinges Includes Complete 15,000 Mile Special
Check Tire Pressure and Adjust if Necessary Plus the Following:
Perform Tire Rotation Install NGK Spark Plugs
Inspect Engine Drive Belts and Install Genuine Acura / Honda Air Filter
Adjust if Necessary Install Genuine Acura / Honda Fuel Filter
Inspect Clutch Adjustment and Install Acura / Honda Distributor Cap and Rotor
Adjust if Necessary (Where Applicable) Replace Radiator Coolant / Anti-Freeze
Inspect Exhaust System (Hangers, Mounts, etc.) Spin Balance 4 Wheels
Inspect all Chassis and Drivetrain Components Change Transmission Oil
Inspect Air Filter For Contamination Change Differential Oil (Where Applicable)
Inspect Engine Timing and Adjust to Factory Specs. Road Test Vehicle
Inspect Engine Speed and Adjust if Necessary
Inspect Front Brake Pads, Calipers, Rotors
Oh i forgot before you hit 60k you should replace your:
Timing Belt
Drive Belts
and Water Pump
seeing they will be down there anyway changing out the Timing Belt, so you wont pay much in labor for the install, a water pump is like 90 bucks so its worth it. I am in NY so for the above it cost me $900 bucks.
I will be dropping the car off on Thursday for the 60k Service, cant wait to see that bill, fun.
Well its the price we pay for having a nice car. Glad I dont own a Lexus. Can only imagine what they would charge.
Timing Belt
Drive Belts
and Water Pump
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 13, 2015 01:59 PM
