Weapon R intake finally here
Attorney- Will Sue 4 Food
NEED HELP
I got my weapon R and am stumped on the directios
I am supposed to Disconnect and remove the fluid transfer line connected to the PVC hose and throttle body coolant line, and remove the throttle body coolant line/
which ones are these?
fight ninja! ya!
Here are the instructions that I got off the site:
1. Using tools remove stock air box ,rubber intake tube and OEM
Clamps, put aside for later use.
2. Disconnect and remove the fluid transfer hardline, connected to the PVC hose and Throttlebody coolant line.
3. Match the Throttlebody Coolant line with the supplied 8mm Silicon Hose, add 2 inches and cut silcion hose.
4. Now replace the Throttlebody Coolant Hose with the Silcion Hose and clamp down with your OEM Clamps.
5. Place the 3" - 3" Silicon Reducer Hose onto the throttle body and clamp down with the OEM clamp.
6. Place a supplied Stainless Steel Clamp onto the other end of the 3"- 3" Reducer hose.
7. Place Weapon*R Intake Tube into the 3" end of Reducer hose and clamp down Stainless Steel Clamp.
8. Match OEM PVC hose to 15mm Silicon Hose, add 2 inches and cut silicon hose.
9. Install 15mm Silicon Hose to Intake pipe port and PVC port on Valve Cover.
10. Install 4mm Silicon Hose onto Intake Pipe and OEM Vaccum hose Location.
11. Attach Weapon*R Filter to end of Weapon*R Intake Pipe, clamp down.
Dragon Filter Option : Place 3"-3" Silicon Adapter Hose on end of pipe and place Weapon*R Dragon Filter into Silicon Adapter. Clamp Dragon Filter and Intake Pipe down with Supplied Clamps.
12. With Supplied Universal Mounting Bracket, bend the flat end of the bracket to the closest mounting point.
13. With the remainder of 10mm Hose, cut a 1/4" stub and put under mounting bracket flush to the mounting point.
14. Mount the bracket to the chassis.
15. With bent end of bracket, slide under the Stainless steel clamp on the filter and clamp down securely.
16. Place Weapon*R CARB Sticker on a visible place in engine compartment. ( If Applicable )
Are these the one's you got? I think the throttle body coolant line is the 8mm one, as stated in Step #3.
Sorry, but that's all I can decipher out of the instructions. I'm looking to buy the Weapon R intake as well. So anymore insight would be greatly appreciated.
Edit: Now that I think about it, after looking at my stock box, there are only 2(?) hoses comming out of the engine to the stock tubing. Those 2 must be the one's that your looking for.
Hope this helps
Hope this helps
rcs86
08-02-2016 06:52 PM
