Vibration at idle
Old Mar 18, 2010 | 12:45 PM
bigdrewz96TL's Avatar
Vibration at idle
I have a pretty shaky vibration when the car is below approx 1200 rpm, above that its smooth.Almost feels like car is going to die but idle is at 750-770 rpm and doesn't fluctuate. If it sits at light for a little while CEL will start flashing, but when I start driving the CEL stops flashing. Car has normal power when above 1200 rpm and goes when I give it gas from idle without hesitation. I haven't looked at the spark plugs yet but checked the wires and everything seem snug.
Any ideas?
Old Mar 18, 2010 | 01:58 PM
TLin401's Avatar
'13 Hyundai Sonata
One of your mounts might be done.
Old Mar 19, 2010 | 06:56 AM
TexasHonda's Avatar
Flashing CEL usually means the engine is missing. Missing causes vibration. Check engine codes (Obd2 code reader) when light comes on to see which cylinders are missing.
Usual reasons are bad spark plugs, wires, distributor cap, distributor rotor. Suggest starting w/ spark plugs, distributor cap/rotor as these are relatively inexpensive. Check wires at night by spraying w/ fine water mist all over wires. Any sparks jumping indicate cracked wires.
good luck
Old Mar 19, 2010 | 01:33 PM
Had oil changed with the timing belt recently and had just got the car back the other day when this started. I checked the oil and they filled it double past the oil mark .
I'm going to have them drain it back down. I'm thinking this might what is causing the misfire with that much oil.
Is that possible???
Old Mar 19, 2010 | 09:13 PM
TexasHonda's Avatar
Too much oil might lead to oil fouling of spark plugs. Ask them to clean and gap plugs.
good luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
