transmition fluid change
Old Aug 14, 2005 | 10:04 PM
veo's Avatar
veo
does transmition fluid have to be flushed or can it just be drained out and new fluid added.
Is it necessary to remove all old fluid?
Can the old fluid be sucked out with a pump instead of draining under the car?
Old Aug 14, 2005 | 10:08 PM
Wampum's Avatar
All you have to do is drain and fill regularly. I believe for the 3.2TL the recommend 30k mile intervals
Old Aug 15, 2005 | 10:34 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Yeah, I just had mine done and I had them change the filter and obviously gasket at the same time. I forgot how smooth this car was SUPPOSED to shift! Works great!! (Normally you don't change the filter, but it's a good friend who owns the tranny shop so I had them do it cause it was cheap), MSRP for filter - $125! My cost - $25!!! Gasket was like $40.
Old Aug 16, 2005 | 12:41 PM
GSteg's Avatar
I guess you can suck out the old fluid, but why? lol. Just drain it or have someone flush it.
Old Aug 16, 2005 | 04:24 PM
hinesktchp's Avatar
woord to ya mother
i got mine serviced today at the dealer and they would not flush my tranny, they said acura reccommends that you dont flush it. i have a 98 3.2
Old Aug 16, 2005 | 04:25 PM
GSteg's Avatar
That's weird. Honda/Acura dealers here and in some other place have flushing services.
I know they dont recommend Engine oil flush, but tranny flush?
Old Aug 16, 2005 | 04:37 PM
hinesktchp's Avatar
woord to ya mother
thats what i thought but thats defintly what the guy told me.
Old Aug 16, 2005 | 09:15 PM
c29842984's Avatar
A lot of places don't care what Honda says but you're not supposed to flush Honda automatic transmissions. Drain and fill only.
Old Aug 16, 2005 | 09:47 PM
Mandy's Avatar
98 3.2 Flamenco Black
Change it every 30K miles, meaning, drain and fill. Will extend life of the tranny. Noticeable lesser "clung" and roughness on shift.
Old Aug 16, 2005 | 10:44 PM
veo's Avatar
veo
what type of transmition fluid is best? is there genuine honda transmition fluid?
Old Aug 16, 2005 | 10:48 PM
c29842984's Avatar
I would recommend you use Honda ATF-Z1 though I've heard you can use regular Dexron III and add a friction modifier and it will work just fine.
Old Aug 17, 2005 | 09:06 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Yup, that's what I did last week. Works fine.
Old Aug 17, 2005 | 06:26 PM
Mandy's Avatar
Honda ATF-Z1, not expensive, recommended, no thinking twice. Stock pile them! Every 12,000 miles, drain and fill, keeps it fresh and so it can go...go...and go.....
Old Aug 18, 2005 | 01:12 AM
veo's Avatar
veo
How many quarts of transmition fluid? Manuel doesn't say.
Old Aug 18, 2005 | 12:40 PM
c29842984's Avatar
I'd get 5 to be safe but you'll need at least 4. At least I did.
Old Aug 18, 2005 | 07:32 PM
98TL's Avatar
5th Gear
where is the screw located?
Old Aug 18, 2005 | 09:33 PM
pi1996's Avatar
about where the gear shifter is.. its written "ATF" with an arrow to bolt..
if you can read, you can't go wrong. heheh..
Old Aug 18, 2005 | 10:30 PM
veo's Avatar
veo
At the dealer they said I only needed 2 maybee 3 quarts. should i go back and get more? how many quarts has everyone else put in?
Old Aug 18, 2005 | 10:41 PM
c29842984's Avatar
Well it's supposed to take 2.9 quarts for a drain and fill. When I dropped my pan I had to put in 4 full quarts. When I did a drain and fill it took 3.5.
Old Aug 19, 2005 | 02:15 PM
veo's Avatar
veo
some say don't change the filter others say you should. i'm confused.
Old Aug 19, 2005 | 04:35 PM
GSteg's Avatar
You don't normally change the filter because most of the time, it still works fine. There is nothing wrong with changing the filter. Then again, I have a friend who changes his filter and fluid at ever 3k miles. He has a legend and legends are known to have very rough shift from 1st to 2nd gear. His car is smoother than a lot of new cars. You wouldn't even be able to feel it shift unless you floor it. But hey, if his method works, I don't see why you shouldn't either (change the filter, not change every 3k)
Old Aug 20, 2005 | 08:00 AM
veo's Avatar
veo
i called the dealer, they said no need to change the filter. also, autozone said the same thing.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ghuns
Sep 16, 2015 04:26 PM
Aleax
Sep 11, 2015 11:31 AM
