you people with 19's could you please post how low your car is ( about for coilover peeps), also post if you have any problems with rubbing , i think that im going to run a 225/35/19 and im going to get the G.C. coilovers sumtime this summer with some tokico illumina(sp) struts and i want to go very low(2.5") and wanted to know if im going to have issues with rubbing i know that somehave had issues with different tires and size rims.. if it rubs i can just raise it to offset this problem but i would like to know what you people ahve your cars set at si i can get an idea in advance .
also there arent people in the back seat hardly ever the most is usually 3 but do you think an 105 lb girl cna do anything
You will definetly need an allignment kitOriginally posted by 962.5TL
For sure camber kit. I have had mine on a 2.25" drop (maybe settled lower) fender goes over the tire about 1/4 to 1/2 in. I have had this drop for over a year. But no real problems with rubbing. None in the back, slight front only when fast, hard turns are made, due to the camber kit.
Running 225/35/19 on a 19"x7.5" w/ +38 offset. You can run 235/35/19 also cause their is still some room inside the fender. But only if the offset is the same as above.
i think the best offset i can get is a + 44 i think , its deffinatly above 40, was it a bad camber very noticable cause im deffinatly not gonna have the 400 to put out right after i buy them? thanx
