Temp Guage goes to H
All about JDM
Hey everyone.
Every now and then, my temp guage spikes to H for a few seconds then goes back down to normal temperature. It seems to happen when Im at a stop light for too long or when i let the car idle in neutral for a while. I made sure to check my radiator fluid in the overflow tank so thats not a problem, but i havent done a radiator or coolant flush cause that'll happen at my 75k service. Any ideas as to the cause and maybe a simple solution? I just got my 60k done but forgot to ask them to check that shit out.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Just an idea, but does your fan come on like other hondas, where it will run often when the car is shut off for a while? my fan seems to come on (I think i have an aftermarket fan in my car, its really loud) if my temp gets just over half...
Swift 3 B-A-N-G-E-R
About the fan coming on... click here...
About your temp guage going to hot... either:
1. You need some coolant in your radiator/resavoir... remember the commercial... "Big Yellow is Taking over!!!"
2. Sensor might be going...
All about JDM
Received 2,329 Likes
Could be either the sensor or you need a coolant flush. I'd get the flush first (since you need it anyway)
I had the same issue for about a week, got a coolant flush and it went back to normal.
You'll also probably experience issues with your A/C and heater until you get it fixed.
-glock security-
hopefully you didnt blow a headgasket
then your in for some $$$$
if the car goes to H ---- shut it off immediately. you will cause more damage the longer it runs hot. heat kills engines. especially aluminum ones.
my temp goes to H (actually right below but close to it). had the thermostat changed and it still spikes up. whenever i see it goes up, i turn on the A/C to full auto and it comes down. i think i need to get it checked out again. the temp never goes up whenever i'm driving at a constent 75-80mph.. but when i drive BELOW 65mph (traffic) the temp goes up slowly..
TL no more!
Like what others said, definitely get your coolant system flushed. Replace the t-stat while at it because a good t-stat costs only $6 (at least for a Stant brand for my Explorer). I have instructions for the replacement if you need it.
All about JDM
Thanks for the help fellas. Ill get the thermostat replaced and do a coolant flush. Ive got the service manual for the ride, but thanks for the heads up Wolf.
TL no more!
Since these engines are computer controlled, I don't think a lower temp t-stat will do anything positive. I know for my Explorer, if I use a lower temp t-stat, the computer will think the engine is cold and as a result, the computer will push more gas into the engine, which will lower your gas mileage and more wear without benefiting anything. Now, if you add a performance chip in there that may require a lower t-stat, then it's fine because the engine will burn all the fuel.
lanechanger
10-13-2015 10:56 AM
