stream cleaning
stream cleaning
does it F up the engine area if i was to get the engine steam cleaned in the spring time? some people advised me not to do it... while others said nothing will happen.... so now i turn to the 1st gen geniuses ( i probably spelled that wrong) @ acurazine! Thanks
I also use a hose and degreaser....sometimes I go to a friends shop and use their high power/pressure hot water sprayer.I cover up the distributor cap.intake.After I'm done,I use air-hose extra water off.
I would cover distributor w/ large, heavy duty zip lock bag to prevent direct spray on the distributor. Never wash a hot engine. I use Simple Green sprayed on for a few minutes before washing w/ pressure washer. I try not to obsess about a little remaining dirt and just get the worst accumulations.
good luck
good luck
I have heard that you should never steam clean an engine. I can cause all kinds of electrical problems because of condensation related issues. Use a degreaser and a pressure washer.
Originally Posted by ACURATECHTX
I agree steam is not the best due to condesation
degreaser and presure washer
oh and TL's dont have distributers only integras and 97-99 CL's
regards
i never had to cover any car when i did it... never had a problem but i always air dried the car before starting it just to make sure electrical is ok..
Originally Posted by TexasHonda
The 2.5TL's have distributors at the back of the cylinder head.
regards
regards
i wasnt thinking of the 2.5...
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
