Stereo install ripoff?
I still have the stock radio and I finally can't take the error code when you play cd's anymore. I have been going to Best buys and Circuit Citys cause they say free install, but every time the sales rep ask what car I have (97 3.2) they want to charge me more cause of some amp thing. Is this true or are they trying to rip me off. Also if I do change radio will all the speakers still work or do I have to change them too?
大日本帝国
Well, if you still want the overhead mid-ranges to work, they will have to splice it in, and add some resistors to convert the signal load to 8 Ohms. Now, not having those isn't so bad. BTW, why pay for someone to do a job that is REALLY easy? Buy a Metra harness adapter and a Metra Turbo double-din to single plate, and you're pretty much set (if you are buying a single-din deck). Unless you are doing some special wiring, go that route and it'll cost you $50 tops.
~Cheers~
~Cheers~
Thanks for the info. I just thought if its free install why not since I still have to buy all the equipment anyways and I don't have a garage, don't want to work on it in the street of NYC. So they are trying to rip me off since there is no special amp stuff to do then right?
If they're saying you have an amp, they're lying. Just have them install the aftermarket CD player normally, no extra wiring. All they have to do is wire a new harness exactly color to color to the stock one. You're going to lose the 2 speakers in the dome light but it's not a big deal. They dont know our cars specifically, they're just going by what a book tells them. Tell them you want the free install and that you have no amp and the harness just has to be connected and if they still wont do it, go somewhere else.
as daemon stated, you just match the color of wires to each other, use electric tape to tape it together and VIOLA. What deck are you planning to get anyway?
Received 2,329 Likes
I'm on my second aftermarket deck on this car and let me tell you, our cars are EASY to work on. The stereo is a piece of cake. Adding in the dome speakers is the only tricky part, but as mentioned its possible with a little know-how.
1998 2.5TL
Ken,
Did you install the Kenwood deck you purchased recently? What is the feedback? Does losing the dome speakers make a significant difference? I'm also considering getting a new head unit, but I'm in a quandary on losing the dome speakers. I really like the sound quality now and I don't want to degrade it. Any input is greatly appreciated.
大日本帝国
The "surround" effect is effectively gone, forgive the pun. I haven't had dome speakers for a LONG time and I still like the quality. I do miss having real surround sound like I did in my Accord, though, hehe.
~Cheers~
~Cheers~
The dome tweeters do make a big difference, mainly b/c its right there on your ear. Once you put in a deck you'll notice the lack of sound. If you want that same effect, youre going to have to buy component sets. The question is where do you want to place your aftermarket tweeters? in the corner of the dashboard? at the dome? if you keep your stock door speakers and stock tweeters at the dashboard with your aftermarket deck, you'll lack the front stage sound. it sucks..
Originally Posted by bpjadhav
Ken,
I did lose the dome speakers for a few days, I didnt miss them too much. I've since wired them into the front speakers. I need to do resistors though, they're a bit louder than I'd like.
THANKYOU ALL as always this forum is great.
I'm just going to go to 1 of the stores and have them install it. Don't know what head unit to get yet, guess i just pick 1 they have not going to spend alot of money cause I park in the street. As for the speakers I guess I have to wait and hear how it sounds first before I decide on speakers. But if anyone have any recommendations on a head unit under $300 that be cool.
Kenwood X979. they dont make it anymore but you can still buy it. that's what i have and the control over your sound is craaaaaaaaaaaaaaaaazy! it takes about a week to learn all the functions and buttons but it's worth it.
head unit under 300 can you plenty. I personally like both alpine and eclipse but alpine looks better in my opinion. If you do get a deck, be sure to get one with a remote. buttons tend to break after awhile of pressing
if you go to circuit city or best buy, they usually have "reduced item" in a glass case somewhere b/c they've been a display item. they're usually high end decks at a great price. they also have reduced price amps too.
大日本帝国
~Cheers~
大日本帝国
gogogo, i notice in your avatar you have a jdm plate holder. where did you get it?
~Cheers~
98 Blue 2.5 TL 200,050 mi
Old thread, I know.
What wires are the dome speaker/midranges near the HU? Are they the green ones with the special plug? And I just hook up an 8 Ohm resistor inline on the positive leads?
Nevermind. Went back to my search for 'dome light speakers' and found my answer: https://acurazine.com/forums/showpos...26&postcount=4
Where are my tweeters hooked up to? Does the stock TL have crossovers? Where are those? Seems my tweets are working..
Just take the wires on the blue harness, cut those and add some resistors to them. Then connect each wire to the respective side on the front speakers.
Your music will sound like it should, otherwise you end up with just 4 speakers.
Ken, thanks for the reply. I understand how to hook up the mids on the ceiling.
BUT my dash tweets aren't working...where to start? Is it the crossover? And where in the world is that?
If I remember correctly the tweeters are part of the blue harness, paired with the midranges.
You shouldn't be able to hear them unless your ears are directly over them.
Huh - I'll have to check that out. From what I could tell, I couldn't hear them at ALL and my music is very muddy at best. I'm sure only the 6.5" (door) and 6x9" (rear) speakers are working.
I've got to get some wire taps and fix this problem (hopefully both the dome light mids AND the dash tweeters)..
Yep, tweeters are on the dash.
I'd almost call the speakers by the dome twiddlers.
snorf
11-04-2019 06:44 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
