Skunk2 Coilovers
Skunk2 Coilovers
hey does ne body have skunk2s if so please tell me how they are and here is a site that sells it http://www.optauto.com/webstore/prod...k=yes&dept=170
hey tam, i don't have skunk2 coilovers but i have a friend who does. he owns an integra and his ride is stiff and noisy when he goes over bumps and those reflecters on the streets. he said it sucks so i recommend GROUND CONTROL. some guys on this forum has ground control but i forgot who. its somebody from houston but you can ask people who has ground control...doesn't have to be from a TL member.
a good friend of mine has skunk2 coilovers for his vigor, which should be a better comparison to the TL as opposed to the integra...
but nevertheless i wasn't impressed with them... don't get me wrong, skunk2's get the job done... u can ride them as low as 3" or more...
it all depends on your preferences right... if you don't mind a really really stiff ride, get the skunk2's...
i don't notice any noise when he's going over bumps other than the normal noises... but the ride is hella stiff... good for cornering, but bad for the back
i dont know if 19's fit 3.2's but i know it does fit for 2.5. theres this guy here from houston, neokinetics, who has 19's...you might want to ask him. i know 18's offset should be 40 and tire size for 18 is 225/40
th ofset you would need would be around a 40 or something higher and then if you plan on lowering the car at all then you should probably run around a 235/35/19 tire as this will be narrow and the sidewall will be tiny( be carefule going over stuff )
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
