resonance vibration?
I've noticed slight vibrations when i accelerate my 96 2.5TL to about 60mph. Below or above this figure, car drives smoothly. Is this resonance vibration or i have a problem
Thanks?
Thanks?
Received 2,329 Likes
It might be your torque converter is trying to lock up in 4th gear but cant quite do it. Its common in some Honda automatics,
Also, you have a 5 cylinder which is naturally unbalanced, so it WILL have some vibration to it.
Swift 3 B-A-N-G-E-R
VIBRATIONS!!! a lo cabron... (translation: Hell of Vibrations [/slang])
Mine shakes now at idle... So i might need to finally change the timeing belt etc...
How do you know its vibrating??? the wheel shakes??? the tires shake???... When in Idle... does it shake???
hope its not the torque converter...
Man I hate vibration...It's wierd, if you try to notice it you will... I will be driving home from work and if my ride vibrates just once I'm like...huh..what was tha? then I freak out about every other little bump i feel... If I'm not thinking about it tho my TL is a BOAT!!
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
