Required Service Intervals for All
3,000 MILE CAR CARE SERVICE 15,000 MILE CAR CARE SERVICE
Replace Engine Oil (Done Also at 45,000; 75,000 Miles)
Install Genuine Acura / Honda Oil Filter Includes Complete 7,500 Mile Special
Check all Fluid Levels - Replenish if Necessary Plus the Following:
Lubricate Door & Hood Hinges Adjust Rear Brakes and Parking Brake
Check Tire Pressure and Adjust if Necessary Replace Transmission Fluid (automatic only)
Inspect and Clean Battery Terminals Adjust Valves to Factory specs.
7,500 MILE CAR CARE SERVICE Replace Valve Cover Gasket
(Done Also at 22,000; 37,500; 52,500; 67,500; 82,500 Miles) Road Test Vehicle
Replace Engine Oil Balance Two Front Tires
Install Genuine Honda/Acura Oil Filter
30,000 MILE CAR CARE SERVICE
Check all Fluid Levels - Replenish if Necessary (Done Also at 60,000; 90,000; 120,000)
Lubricate Door & Hood Hinges Includes Complete 15,000 Mile Special
Check Tire Pressure and Adjust if Necessary Plus the Following:
Perform Tire Rotation Install NGK Spark Plugs
Inspect Engine Drive Belts and Install Genuine Acura / Honda Air Filter
Adjust if Necessary Install Genuine Acura / Honda Fuel Filter
Inspect Clutch Adjustment and Install Acura / Honda Distributor Cap and Rotor
Adjust if Necessary (Where Applicable) Replace Radiator Coolant / Anti-Freeze
Inspect Exhaust System (Hangers, Mounts, etc.) Spin Balance 4 Wheels
Inspect all Chassis and Drivetrain Components Change Transmission Oil
Inspect Air Filter For Contamination Change Differential Oil (Where Applicable)
Inspect Engine Timing and Adjust to Factory Specs. Road Test Vehicle
Inspect Engine Speed and Adjust if Necessary
Inspect Front Brake Pads, Calipers, Rotors
