rattling from front passenger side?
Old Dec 22, 2011 | 07:18 AM
Fanir's Avatar
I keep getting a rattling sound coming from my front passenger side, it sounds like it coming from the wheel area. It only happens when going slow maybe (5-20 mph) over small bumps.
Im going to pull off the wheel and check it out this weekend, but I was wondering if any of you have had this problem or have any suggestions on what it could be. It drives me nuts hearing it all the time.
Old Dec 22, 2011 | 07:21 AM
KaMLuNg's Avatar
check your upper control arm... when mine did that it was the ball joint on top...
Old Dec 22, 2011 | 07:54 AM
Fanir's Avatar
Ok thanks. I will check it out. If it turns out to be bad, does the whole control arm have to replaced or can I install a new balljoint?
I looked at a diagram on my repair manual and it looks like the balljoint is pressed in?
Old Dec 23, 2011 | 10:05 PM
KrayzieDxC's Avatar
Khmer Pride
before taking off the wheel. check your movement from your tires side to side and top and bottom. if you stuck on good then your good.
Old Mar 21, 2012 | 11:56 PM
benny1562's Avatar
Mine does the same thing, I believe its actually the exhaust, I just replaced my uppercontrol arm cuz I had a bad passenger upper ball joint and I still get this noise, I can also hear it when slamming the door shut, I had my friend do this while I was changing the oil and it was something on theexhaust
Old May 26, 2012 | 10:34 AM
SmokenTL420's Avatar
I'm having the same problem. I think it might be the shield over the catalytic. Mine started to do this after the 02 sensors were changed which is why I think its the cat shield.
HairyMonkey019
Apr 22, 2016 10:50 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
