Rack and Pinion
Old Apr 8, 2006 | 03:11 PM
BigHoop65's Avatar
4th Gear
Unhappy Rack and Pinion
Not too long ago my mechanic pointed out that fluid was leaking from my steering column
The place that i go to for all my engine work does very quality work (shiny AAA awards for customer service at the front desk and all)
They told me that if the fluid continues to leak that my entired rack and pinion will have to be replaced......... on top of the fact that my timing belt is due up for a change AND battery acid ate away at my positive cable
Suggestions people?? One at a time.... all at once..... help me knock this out
I'm a brand new member and my first thread..... i figured the acura heads here could give me more perspective
Old Apr 8, 2006 | 03:27 PM
Pure Adrenaline's Avatar
Dragging knees in
Timing belt/water pump will cost you somewhere in the neighborhood of 700-1,000 dollars. How many miles do you have on the car?
As for the battery problem, use baking soda to clean the posts and the terminals. If the terminals are too messed up, then get new ones. They cost like 5 bucks.
As for the steering column... beats the hell out of me. I don't know why the rack would have to be replaced if it's just the pinion that seems to be the problem. Why don't you get a second opinion at a different shop?
Welcome to the forum.
Old Apr 8, 2006 | 04:26 PM
BigHoop65's Avatar
4th Gear
i'm sitting on 116 thousand right now..... i know i'm due for a timing belt/waterpump job..... it's taken me a while to get the money together for that...... but the issue with the battery cable and the steering fluid leak is my bigger concern cuz i'm worried about how much that's gonna set my money back
i do intend to get a second and third opinion
Old Apr 8, 2006 | 06:22 PM
Ken1997TL's Avatar
2nd and 3rd opinion for sure
Old Apr 9, 2006 | 08:18 AM
racerock's Avatar
Read my recent post on the timing belt thread.
Old Apr 9, 2006 | 08:38 AM
TexasHonda's Avatar
I would suggest trying a bottle of Lucas PS Stop Leak. If the leak is due to hardened seal, this may soften the seal enough to stop the leak. My father had a 97 Avalon w/ a rack & pinion leak, about a teaspoon or so overnight. After the Lucas PS stop leak, the leak stopped w/i a week and has not returned after 2 yrs.
good luck
Old Apr 9, 2006 | 05:04 PM
BigHoop65's Avatar
4th Gear
good luck
where can i find that??
Old Apr 9, 2006 | 07:32 PM
TexasHonda's Avatar
Lucas PS Stop Leak is available at most auto parts stores. Call the major chains and check.
good luck
dirleton
20
Oct 16, 2015 01:48 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
miguelalanis
Sep 21, 2015 01:04 PM
CaliBud916
Sep 19, 2015 01:56 PM
