question...
Old Nov 29, 2001 | 05:15 AM
question...
want to get my car lowered. is there any way to compensate for the weight of a motorcycle once it's dropped? i have to have my bike at the beach rallies. having my tl there would be nice also...
Old Nov 29, 2001 | 05:27 PM
you could install height adjustable shocks, i'm not sure from which company.--or--a coilover system such as those from Ground Control...maybe a combo of both? how about an airbag system with an internal compressor? hope this helps.....aloha....
Old Nov 29, 2001 | 09:38 PM
TL12's Avatar
In your case of hauling your motorcycle, I would stay away from progressive lowering springs and go with a linear type. The progressive is very soft for the first couple of inches to give you a comfortable ride. With the weight of your motocycle at the back, your car will definitely drop down quite a bit at the rear before the spring stiffens.
Adjustable shocks, either coil-overs or height adjustable shocks are okay, but may become a hassle after changing it over and over again. Also, if you change your height, the wheel alignment goes off and you could wear down your tires prematurely.
cusdaddy
Mar 13, 2006 04:13 AM
D73
May 29, 2002 03:58 PM
