Programming New Remote
Old Jun 5, 2004 | 04:29 PM
myfirstAC's Avatar
I bought a second transmitter off of Ebay recently and now I'm looking for help on how to program it. Does anyone know how to do it, or would I have to bring it to the dealer?? Any help is appreciated.
Also, I just replaced the muffler on my car and so now I'm looking for chrome tips to replace my old rusted ones. The store I got them from before recently closed so now I dont know where i should get em...Anyone know a good spot online or in the NY metropolitan area?
Old Jun 5, 2004 | 04:35 PM
=]Shinoshi[='s Avatar
fight ninja! ya!
Programming the Transmitter
NOTES:
• This system accepts up to two transmitters.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all the transmitters once you’re in the
programming mode.
1. Open the driver’s door.
2. Push up the driver’s door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the “LOCK” or “UNLOCK” button on the
transmitter. Make sure the power door locks (all
except the driver’s door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its “LOCK”
or “UNLOCK” button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
Ordering a Transmitter
Transmitters can be ordered only by authorized Acura
dealers. Order them from American Honda using
normal parts ordering procedures.
Batteries for the Transmitter
The battery number is CR2016. Each transmitter uses
two batteries.
Hope this helps ya
Old Jun 5, 2004 | 06:55 PM
sonicblue's Avatar
http://www.acuraautomotiveparts.org carries - I think - pretty much every OEM part. The exhaust finishing tip I think you're talking about is $70/pair.
Old Jun 9, 2004 | 12:24 PM
tlw
98 TL 2.5
Shinoshi's instructions are the same that worked for me with my eBay $25 remote, now I have two working remotes...
TLW
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
