Programing Keyless Entry...
Old Mar 31, 2004 | 11:12 PM
NickP10's Avatar
I just purchased a keyless remote from ebay for my 96 TL...the guy gave me some weird instructions and havnt been successful in programming it...does anyone have any easy ideas on how i would be able to do it?
Old Apr 1, 2004 | 02:40 AM
Ken1997TL's Avatar
Here are the instructions for the 3.2 (I cant find any for the 2.5, i don't think it is programmable, the 1998 2.5 is the exception, it uses the same setup as the 3.2)
1. Open the driver’s door.
2. Push up the driver’s door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the “LOCK” or “UNLOCK” button on the
transmitter. Make sure the power door locks (all
except the driver’s door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its “LOCK”
or “UNLOCK” button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
Old Mar 20, 2007 | 09:42 PM
scott3travis's Avatar
99 TL Keyless entry instructions? Help please
Hello, I tried some instructions on this forum for a 97 TL I think. Anyway, they didn't seem to work for my '99 TL 3.2. Does anyone have any instructions to program my keyless entry remote? Many Thanks!!
Old Sep 18, 2007 | 08:14 PM
Ken1997TL---THANKS!! Just got a new remote from Delray for my 1998 3.2 TL. It worked exactly as you said. Appreciate the instructions!!!!
Dan J.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
tman570
Jun 11, 2019 07:56 AM
joflewbyu2
Oct 8, 2015 11:16 AM
GraveDigger
Sep 18, 2015 07:46 AM
Sep 17, 2015 09:01 PM
