Power Steering fluid chnage
I replaced power steering fluid today.
It is probably one of the easiest diy. It took me about 10 minutes.
The fluid was completely black.
How often should this be changed?
generally every 15-30k miles or few years
Thats more than what the book says- but I would rather be safe
大日本帝国
I disconnected the power steering pump and it spilled from one of the hoses. Since it's a pressurized system, you don't need to bleed it like you do brakes. Doesn't take much, either.
~Cheers~
~Cheers~
my power steering pump is leaking like crazy and noisy as all hell. So i assume it is going out and will need replacing. Any idea on cost and is it possible to get a rebuilt one instead of brand new, or is that a bad idea?
I used Bardahl Power steering fluid.
It says “Honda and Acura” on it.
First I used a turkey baster to empty out the container. Than I unplug the return hose, I attached a longer hose on the return hose, put a small empty milk container at the hose and started up the car. I dumped all the used fluid in it.
I attached the return hose back to power steering fluid reservoir, poured new fluid in it. Than started up the car the move steering wheel from one end to other few times. I rechecked and filled fluid level to max position.
Whole thing took about 10 minutes.
Bardahl's Honda Power Steering Fluid
IT was clear? I got the same stuff and it was browish clear.
Guys, you are scaring me now.
I will go to the dealership and get the real stuff, since it only takes 10 mins to drain and refill.
大日本帝国
it looked liked clear to me.
~Cheers~
Originally Posted by Go90go
Meh, who cares. It works, doesn't it? Sure OEM is better, but I drove with barely anything in there until I had a chance to get some.
~Cheers~
~Cheers~
98 3.2 Flamenco Black
I just looked at my power steering reservoir and the fluid is brown and smells burnt. I have a 12 Oz Honda fluid and it smells fresh...and almost clear.
I have 88K, time to drain and fill. Service manual says 1.5 qts to remove all fluid. Very easy directions. I must get me 2 bottles of the honda fluid!!!!
Does changing the PS fluid make the wheel easier to turn? Since my wheel is really hard to turn when it's real cold outside (winter). In summer it feels OK, but the other day I drove an A6 and it was unbelievably easy to turn the wheel; I can steer when the car is stationary only with my pinky finger which is impossible with the TL.
And why does the dealer say that you shouldn't change the PS fluid?
Did you inspect the fluid...is it anywhere close to looking like fluid?
It's a 30 min job, why not just replace the fluid and see if it helps.
The steering in the TL is the lightest I've experienced in any car I've driven. I changed the PS fluid last year at a Honda dealership and I didn't notice any difference afterwards.
Tried to do my differential fluid today but my fill bolt does not want to budge....I have to get a breaker bar or an extension to break it loose....shoot I do not remember tightening it that much when I changed it at 58K. I am now 88K, time for a drain and fill...
Well I went to a Honda dealer a few weeks ago for an oil change and asked them to change the PS fluid. The service guy said they don't ever change power steering fluid. To be sure he called a local Acura dealer and asked if they ever change it, but they said no.
So WTF? It was mentioned earlier in this thread that the manual and dealers say that it doesn't need to be changed, but I still find this really weird.
So to the people who changed their PS fluid - where did you go, if you did it yourselves where did you buy the fluid, and most importantly did you see an improvement?
Fresh power steering fluid helps. The manual gives you instructions on how to replace. I just do not know at what mileage. I am scheduling a drain and fill shortly, I have 88k.
Like I said I changed mine last year at a Honda dealership in Toronto. Midas can do it too, the guy there was telling me the other day the fluid look bad and should be changed. But he didn't have Honda fluid so I didn't have to argue.
大日本帝国
~Cheers~
If you don't replace the PS reservoir, fluid will likely be dirty again due to filter element in the bottom of the reservoir that traps particles. I've never replaced my PS fluid, but topped up occasionally and it's very dark.
good luck
good luck
mike from annapolis
05-07-2017 08:21 PM
