Painting the side skirts?
Hey guys,
I was wondering if any of yall have ever removed the black side skirts and painted them? If so, what kind of paint did you use, and did you do any sanding or anything?
Thanks!
Thanks!
Str8 Home built
I had some cokaine white letf over from my paint job... Wash them with dish soap.. spray them with adheasive promotor.... Then used primer surfacer.. sanded with 400 grit sand paper... Then cleaned them one more times... Then sprayed them with my basie white the clear coat... The paint i used is ppg urathane...any questions let me know
& how long did it take? Id be willingto spend like 100 bucks on supplies i guess.
You use spray paint?
Str8 Home built
Removing the clips at the bottom suk to remove.. then there is 2 screws in the front of the side skirt.. the u have to push the skirt foward with a rubber hammer and they will slide off... The adheasive promotor comes in a can and so does the primer sufacer.. this can be bought at ur local body shop supplies store.. as for the paint it was not a spray can it is real urathan ppg paint. Can only be sprayed with a paint gun. Soo with 1 quart of paint and clear i belive ur looking at 120 to 150. Depending on what brand u get and quality of it as well.. so buy the time ur done ur lookong at 200. Also dont forget the paint both... I did mine the way i explained it to u here and the paint has not peeled or anything like that panint still looks clean
BoricuaTL
04-08-2016 01:08 PM
acurajj
02-14-2016 02:28 PM
09-04-2015 08:03 AM
