NYC mechanics
NYC mechanics
hey everyone looking for a well experienced Acura mechanic. I live in the Bronx. I need to get maintenance and mounts, and valve stems done. Any info would be great. Thanks
blue smoke means you are burning oil. I think you are having the same problem I am having. take out 1 spark plug and see if there is oil on it. if so, you will need to either change out the head gasket or spark plug seal. I need to do that too
spark plug seal? hmm that could be an idea to. I think im also burning anti freeze ever so slightly. 2 weeks ago the oil change placed filled the overflow tank to full now its at min, SUCKS!!!
Just curious, but would the extended emission warranty cover that? I read over it didnt see gaskets or seals!
Your Friendly Canadian
Received 1,485 Likes
there's a member on here, 06 Acura TL, who has a bodyshop in the NYC area. he should be able to help you
Originally Posted by TLBaller
blue smoke means you are burning oil. I think you are having the same problem I am having. take out 1 spark plug and see if there is oil on it. if so, you will need to either change out the head gasket or spark plug seal. I need to do that too ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
