Nooby with question
3rd Gear
Nooby with question
Hi guys,
I got a 96 2.6 tl, my starter died and i'm planning to replace it myself. Can you tell me which is the starter (my guess is the lower one)? ... yeah yeah, i know...![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
and anything i need to know when removing it? any tips will be appreciated.
Bryan
![](http://www.1112studio.com/download/tl_engine.gif)
Bryan
STOP!
Before you spend more money than the car is worth!
Call up a local parts place and ask, What repare shop is the best and most honest in the aera! Then have them do it for you.
At least go to the parts place and look at one first. The picture that you have doesn`t have the starter on it! It shows the alt. and the AC Copressor, You don`t want to mess with either one!
You`ll save your self a bundle of money and it will get done right the first time.
Good Luck!
Good Luck!
Reppin' the T-Dot!!
1 Post
I've done it
The starter is located on the driver's side towards the BACK of the engine. You will have to remove the Driver's side wheel AND DRIVESHAFT to be able to remove it. If you don't have accesss to a full hoist, it is going to be a pain in the butt, trust me, I did it WITH a hoist and it was a pain to get to. Some of the bolts, particularly the upper one are very difficult as well, as the exhaust is in the way. If there is a good respectable re-build shop in your are call them and take it to themmost can have it back within the day if you get it to them soon enough. Otherwise you are looking at over $300 to pruchase one, and almost $500 from the dealer. Hope this helps.
Reppin' the T-Dot!!
1 Post
Dude, was in a hurry when i read first post, didn't realize you had a 2.5, mine's a 3.2, don't know the 2.5 too well. My apologies, hope I didn't send you down the wrong path! Good luck still man.
yeah 2.5 engine is diff than 3.2.. i dont know what diff there is but i do know the intake is on the other side of the car..facing the opposite direction. 2.5 does not have a engine cover either
The starter in the 2.5 should be directly under your intake manifold, in order to gain access to the starter you will have to remove the intake manifold, a very cumbersome and messy process if you ask me. A lot of nuts and bolts in hard to reach areas. But if you like to get down and dirty, I had mine out in less than 20 mins, but don't forget where everything goes :wow:
Originally posted by TLBaller
whats up liem! wow, another houston member. got any pics of your TL?
Welcome to the forums!
Hi,
whats up baller? Thank you for welcoming me. As of now I have no pics of car, but I will try to borrow a digicam from someone.
Liem
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
