New Issue????
Old Nov 28, 2007 | 09:52 AM
Oldyota's Avatar
Just a user
New Issue????
So this morning I get my car and fire her up, pull out of the drive way and get on the road and my ABS & TCS dash lights come on.... Now the button for the TCS is always off and the ABS light has never come on before..... I hoping this isn't an electrical issue, but fearing that it is... Has anyone had this happen, and I haven't done anything to the car prior to this issue.. Thanks in advance...
Old Nov 28, 2007 | 02:19 PM
Go90go's Avatar
大日本帝国
Weak battery or alternator can cause this, but you'd have the charging indicator lit if it was the alternator. Try testing a different battery to see if that makes it go away. If it doesn't, then maybe an ABS sensor is damaged.
~Cheers~
Old Nov 28, 2007 | 02:42 PM
KrayzieDxC's Avatar
Khmer Pride
yes, i had the abs ..now it finally gone it was the dam battery causing the abs ..."ignition voltage"
if u go under ur passenger side and you will find a blue clip, you want to get a paper clip and make a U shape of it and put it in the blue clip. then u want to turn on your car to ON and look at the ABS light and see how many flashes it makes.
Old Nov 28, 2007 | 02:55 PM
Oldyota's Avatar
Just a user
Where on the passenger side? In the car under the dash or under the hood?? And so what do I do if it blinks? I would think that is throwing a code but how do I interpret it??
Old Nov 28, 2007 | 06:33 PM
KrayzieDxC's Avatar
Khmer Pride
under the dash ..passenger side. it blinks , first codes will be long codes then the 2nd codes will be short codes so you will be counting them like 6-1 it will be 6 long blink and 1 short blink
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
