Need wiring diagram
Need wiring diagram
Hey guys, i have a problem with my cooling fans being on the whole time while im driving. Looked at every single connectors that has to do with the cooling system. Even with car cold and the ignition switch at the On position the fan turns on, its driving me nuts!! Does anybody have the wiring diagram for the cooling system? thanks
Khmer Pride
its suppose to be on. its to keep ur engine cooler when its hot. if u drive your car for 1 hr or more it will stay on for 20 mins or less and it will auto shut off
大日本帝国
They're NOT supposed to be on all the time. Mine rarely come on after the swap, and my digital gauges read about 190*F during driving, which is normal operating temp. There's the a link to download the service manual in the Problems & Fixes sub-forum, IIRC. Go take a look there.
~Cheers~
~Cheers~
I don't know about 3.2TL, but most Hondas and Acuras use a thermoswtich to control the fans. Thermoswitch is usually located near the the thermostat housing. Pull connector and if fans go off, you've found the problem, a shorted thermoswitch A.
good luck
good luck
Thanks guys for all the replies. I found out the mechanic that worked on my car had the fan temp connector on the radiator swapped with the a/c connector. Thats it for me on taking my car to the mechanic. Im gna start doin all the work on my baby from now on. Thanks again guys for the replies, helped alot on giving me an idea where i should start first...
quanaman
01-09-2023 07:33 PM
SUPRMN84
10-07-2015 09:46 PM
AmplifiedDetails
09-24-2015 02:55 PM
