Need Rear Brake Pads
Hey guys I need to get a set of rear break pads. Does anyone have experience in aftermarket pads? Recommend anyone? I saw there are a few on this site AEM and a couple other brands. Also does anyone have a step by step how to replace them. Thanks
Who Needs a Type-S?
I have AEM pads and they are great.I can't really give you an accurate estimate regarding braking power because there's no way for me to test that, plus I put on my heavier CL-S rims at the same time. They do offer enhanced pedal feel though..very linear and they grab hard even when cold. Can't tell you how to install tho, my shop did it for me. If you have a Acura Service Manual you could do it yourself. It just involves taking off the wheel, removing a few bolts attched to the caliper etc etc.
Just curious as to why you need rear brake pads, did you already replace your front set?
I'm running organic ones from AutoZone.
They suck, it was only $12 bucks though.
I recently purchased Factory Acura pads for $60 at the dealership and plan on replacing them soon.
If you've done brake jobs before then it's pretty simple except for the cylinders do not get PUSHED back using claps.
The Rear brakes have a + looking grove in them and that cylinder needs to be TURNED CLOCKWISE to move them back for the new pads to fit. I used a needle nose pliers to do the job.
This wont make sense right now but once you have it apart, you'll see what I mean.
Print this out and take it down with you just in case you want to re-read it.
again, dont push the calibers back but TURN the calibers clockwise using a needle nose pliers for the rear brake job
Mola
Mola
i just got the lifetime brake pads from Pep Boys...theyve lasted for about 3 years. the good thing about the lifetime is that you just have to take them into Pep Boys when they are worn down and exchange them for new ones for free.
Mola is right about the cyclinder...it is a pain in the ass to push in. there is actually a small circular tool that attaches to a socket wrench and you can use that for turning the cyclinder..i got it at Pep Boys.
yeah, i'm looking for new brake pads too. i think i'm going to get the AEM ones too. my brakes are worn pretty bad. when i step on them hard i can hear a scratching sound. and it definitely takes longer to stop. i'm going to order mine soon. i'll let everyone know how they are.
mada51589
05-03-2022 08:54 PM
