Need a little help installing Intake..
This is what I got today..
![](http://i157.photobucket.com/albums/t51/tony372/91-_legend_red.jpg)
I have color coded little holes.
1. Biggest hose [in red circle] goes into the one coming from intake manifold. (right or wrong)??
2. Medium sized [in black circle] goes into the one coming from valve cover. (right or wrong)??
3. Where this small third one goes [ in blue circle]???
and one more thing. If you guys with intakes can post pics of your setup please.
(especially you bwallace530, because I think we got same intake)
Default
Where everything plugs into is pretty straight-forward since the tubes are pretty close to the same size as the holes in the intake. But I just found out it's not exactly plug and play.
![](http://img.photobucket.com/albums/v194/DarkNinja75/intake.jpg)
Blue: what's stock is normally a 90 degree plastic piece. But the plastic piece isn't big enough to fit over the new intake's hole. The stock tube by itself is also too big for the hole. So you'll need either a slightly bigger piece of plastic, or another small piece of tube.
Red: This thing has to stay there. You unhook it from the stock setup, but it has another tube attached to it that you need to keep connected.
Black: the blue tube that comes with the intake would actually work here. You have to use a bit of force to get it hooked onto the engine, and it slides on easily to the intake. I recommend getting another clamp to hold it onto the intake since it's too loose to me.
Yellow: the stock tube is too short. You'll need to buy a longer one.
Green: the blue sleeve they give you isn't long enough. You need a longer one or the intake will be bent at some crazy angle and it won't fit.
Orange: You might need another large tube to extend the intake so it fits. Not sure exactly.
So what it looks like you (and I) will need are:
- 2 large tubes for main intake
- 2-4 clamps for large tubes
- 1 small clamp for included tube
- 1 medium tube (to replace 90 degree plastic)
- 1 clamp for medium tube
- 1 small, long tube
Default
Stock it's plugged into a little 90 degree metal tube that goes into the intake. But the stock one is more on top and about 5 inches to the right. As to what it's plugged into on the engine, I'm not sure, but you only have to detach the intake end.
So I am just done installing intake. It sounds so damn good. As soon as you go past 4000 RPM it sounds like VTEC
TLin401, If I record a video its gonna be crappy. I'll try though
![MMM](https://acurazine.com/forums/images/smilies/mmm.gif)
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Received 2,329 Likes
You can actually just delete the old metal hardline hoses and just loop those coolant hoses underneath the TB. I'm not even sure why they would loop coolant hoses underneath the vacuum lines for the intake. You can also do the coolant throttle body bypass while you're at it.
大日本帝国
The hardlines we're referring to are the two pipes that are stuck together with the bracket. Can't miss it.
~Cheers~
Hey Guys, I have that same intake and it kinda was a pain in the a$$ to put in the coolant hoses i dont no what to do with them i went to unplug them and coolant went everywhere so i hurryied up and put it back together
what is the blue tube attached to?
and is the radiator tube still hooked up?
i have my blue tube hooked where the radiator one is i have the same kit it kinda doesnt really come with everything.
what filter do you have i have the one that it came with but i dont like it at all.
大日本帝国
Some guy ran me off the road today and then when i stopped to get his info he ran into the other side of my car!!!
where do i find acura fenders bumpers and how to get dents out of our doors anything would help thank you
Default
People scare me sometimes.
Check out some junkyards. I know one near me just got a '98 TL with a smashed in trunk that they've been parting out on Craigslist.
Default
'13 Hyundai Sonata
has anyone done timing belt and water pump on there car could you tell me if its hard and how long it should take? thank you
and if anyone has pics and the cheapest place to get the parts that would be a plus
'13 Hyundai Sonata
acuraoemparts.com
The parts will cost you like $40 then labor will be like $500+![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Start another thread or do a search because there is a TON on this.
