Need help with driver side headlight
Old Oct 21, 2010 | 12:09 PM
siego99344's Avatar
8th Gear
Hey guys i have a problem with my light, My light went out and i went to go get a new light bulb and that didnt even turn on, it only turns on with my hi beams on, also i notice when i turn my high beams on the passenger light goes dim and my driver side light is on hi beam but when i turn off the high beam the passenger light is normal but the driver side light is off[IMG]/forums/images.old/smilies/mad.gif[/IMG]. Not even the fog lights turn on and they are new lights. What could be the problem? thanks guys
Old Oct 21, 2010 | 08:46 PM
TexasHonda's Avatar
A failing dimmer relay might cause this problem. Also putting wrong headlight bulb in or not fully seating might cause some funny problems.
A failing combination switch might cause the fog lights not to come on, but hard to see how this could produce the alternate bright/dim headlight combinations.
good luck
Old Oct 22, 2010 | 09:27 PM
siego99344's Avatar
8th Gear
Do you know where the dimmer rely is located? its a 1998 acura tl 3.2.. thanks
Old Oct 23, 2010 | 05:35 AM
Go90go's Avatar
大日本帝国
Clean the plug. It should be a bad ground.
~Cheers~
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 16, 2015 03:29 PM
JnC
Sep 11, 2015 06:06 AM
